MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Sun Aug 17, 2003 11:14 am
Ahh...so just from this post, 95_240sx says I probably don't need one, and C-Kwik says I do need one...I'm running rich, and I'm trying to get rid of that problem, I think it's worth a shot to run it w/o the stock FPR. So wouldn't I get less fuel (not run as rich) with just the bosch RRFPR? After all, cars that come turbocharged stock have only one RRFPR...
And no, the one I'm using isn't adjustable...I already checked for boost leaks numerous times...there aren't many places that it can be leaking (I'm only running alc injection right now, the hotside pipe is one piece steel and pretty straight-forward)....I'm not running a true BOV, I'm running a compressor bypass valve...I'm using the one from an Audi TT...it's a closed loop system, it goes from the hot-side pipe and plumbs back into the turbo inlet...no leaks in the the CBV, I already checked it....
I know RRFPR are not the best way to go, but then again, I don't have an unlimited budget, nor do I ever abuse my car. When I drive it to work, I keep it under vacuum for pretty much the whole way, it doesn't see boost more than 50% of the time when I'm driving, and as I said, past 4500 RPM, it's only at like 6 psi (yeah, the turbo isn't exactly matched that well to the engine). Ideally, I'd do 370cc SR injectors, a hacked MAF and a JWT ECU...but if I had that kind of money, I wouldn't be complaining to you all about problems now! Is there a cheap, safe alternative to what I'm doing right now?
Thanks for the input guys...
