rexhunta »
https://forums.nicoclub.com/rexhunta-u25385.html
Sun Nov 20, 2005 3:44 am
Have a talk to a local tuner about it, and see if he can have a look..
If your running stock injectors/pump you shouldn't be running rich without another problem like a faulty fuel pressure regulator.
Actualy, another cause of running rich is a faulty water temp sender. A faulty sender will give the ecu an incorrect reading e.g. freezing cold which will dump eaxtra fuel in too.
Pete
