evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Jun 20, 2010 7:35 pm
do not use "block sealant" ever, it's bad stuff, it sticks in all the wrong places, like your radiator, heater coer, overflow canister, valley of the block etc, and it's a real pita to dig it otu of the bblock later on
as yfor holding pressure, you said it bled down form 15 psi, you presurazed the system and it beld down to 4 psi in just a few minutes? it's leaking somewhere, look in the interior for a leak at the heater core, look at the radiator for leaks, look at the little coolant hoses going to the tb, look around the waterpump and thermostat, if oyu can't find it there pull out the spark plugs, and look and listen for signs of leakage into the cylinders
