skipper6567 »
https://forums.nicoclub.com/skipper6567-u182973.html
Fri Apr 29, 2011 6:53 am
Hi all I have 99 i30 that seems to run fine above idle,there is some "hunting" at higher rpm. The problem is at idle,starting. The engine first fires up and tach goes to 12-1500rpms,drops to 500-650rpm almost immediatly.I have gone to the j/yard and got all sensors, I have removed plenum and throttle /iac /egr tubes all map/bro/swirl valve/camshaft sensor/map/ cleaned and checked all these components,The engine seems to have a steady miss? I do NOT have a check engine light at this time. I do get knock code sometimes. The tps seems to have intermittent voltage without engine running? Its hard with digital meter but seems like one of my probes is being tapped on the battery ground. 12vdrops to 0 back to 12-3-11-12-3-12 all this in a matter of seconds? should be constant? correct? what send the signal to the tps? Im running out of sensors and things to test..also all coils/plugs replaced,no smoke or carbon in exhaust.The egr tubes were blocked solid. now they are all clear.seems that I'm not the only one with this problem. Just that no code?? I also want to add that when engine is running and I disconnect iac=no engine change,front o2 sensor disconnected =no change=egr=no change??tps=no change??
skipper6567 on Fri Apr 29, 2011 7:25 am, edited 1 time in total.
