bt1 »
https://forums.nicoclub.com/bt1-u59524.html
Mon Mar 12, 2007 9:52 pm
Here the problem. Drove to work in the other morning car was okay. I started the car after work and immediately noticed a rough idle. The car could barely idle in drive. When accelerating the car misses and stumbles. Got home and did a little checking, found out that when I removed the NO. 1 COIL wire there was no change to the idle. The other coil wires all had a chage in idle. Changed the spark plugs, no change. Switched the coil with the other cyclinder, no change to No. 1 cyclinder. Took a compression test on all cyclinders and all were okay. Replaced the No.1 fuel injector. still have the problem. Does anyone have any suggestiion?THANKS
1993 Maxima SE 117,000 Auto
