digimon »
https://forums.nicoclub.com/digimon-u276651.html
Mon Dec 09, 2024 9:02 am
Hello,
This car does not have autolight system or fog lights, and I suspect that headlights do not work correctly.
When I put the light switch in the first position, the small light indicator on the dashboard comes on and the small amber lights turn on.
When I turn the light switch more into the second position, nothing changes on the dashboard and the outer lights turn on.
When I push the lever forward for high beam, the high beam indicator on dashboard comes on and the inner lights turn on, when I pull the lever back the inner lights and high beam indicator turn off.
So, in low beam position only the outer lights are on, and the inner lights come on only in high beam position.
Is this the correct behavior?
Also, if the car does not have headlight aiming control, is it possible to change the aiming of the outer lights. I would like to lower them a bit.
Thanks.
