rim specifications
FD3S
does anyone happen to know the specifications for the versa rim?
i was looking at aftermarket rims and was wondering if this would fit:
15" x 7Offset: +42mm Bolt Pattern: 4-114Rec. Tire Size: 185/65-15**Lightweight: 14.5lbs.**Note: Vehicle Has TPMS
they are motegi racing sp10 and cost around 150 each
blindsnyper
Car: 2007 versa
yes they should work
my_new_v
Car: 2008 Toyota Tacoma X-Runner
Those do fit...I was about to buy those myself but now I have other things in mind.
TheClevelandSound
Car: 2007 Nissan Versa
Are u sure? Im getting rims on today and i had to buy 195/60/15s because they didnt fit my stock 185/65/15s.
They were 15x7s
bulld0g
Car: 2007 Nissan Versa SL "Bulld0g Edition"
TheClevelandSound wrote:Are u sure? Im getting rims on today and i had to buy 195/60/15s because they didnt fit my stock 185/65/15s.
They were 15x7s
you had to get a a wider tire due to the new rim width. the stock rims are only 15X6
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
bulld0g wrote: you had to get a a wider tire due to the new rim width. the stock rims are only 15X6
But the rims that FD3S is showing are also 15x7's, like TheClevelandSound's.
All I can say is my 7" wide rims are rolling 215's. It's possible the 185's ARE too narrow, or maybe there is a difference between the lips on the two wheels and one can accommodate the smaller tire, while the other can't.
biggie
I'm sure the 185/15 could be made to fit on the 15x7 wheel, just they probably didn't want to and told you you needed bigger (but its best to have a wider tire otherwise a wider wheel is useless).
I would go no less than 205 tires on a 7" wheel. 215 and 225 (possibly) as options.
TheClevelandSound
no actually u are incorrect. The bead has a 50% chance of breaking if u put those rims on. They will tell u that at any shop. I just went to get my rims put on, but the used tires i bought were pieces of **** so they wouldnt do it and also they all werent H types. Im sooo pissed, everything possible has happened wrong. I will never ever have these rims on my car.
my_new_v
Awww want a hug? lol jk
You will man, give it time, save up the money, and buy 4 good brand new tires
