TexRodeo »
https://forums.nicoclub.com/texrodeo-u130352.html
Sun Apr 03, 2011 10:46 am
I have run into some differences for the FOB or remote control programming procedure. I have had a very difficult time with my security system for just over a month now. I have a 1993 Infiniti J30 and have replaced my remote control box in the trunk 4 times and the Theft Control module very far under the dash once to address these issues. I had viewed a video clip on YouTube that showed programming procedures for an early to mid-90's Nissan Z-Car FOB, Since there were some similarities to the Z-Car and the J30, I figured that I would give it a try and it worked perfectly. There were a couple of distinct differences in the procedure from the J30 Service manual to the procedure that worked. Also, I was able to ascertain that there is NO BCM or Body Control module on my J30. I will list the original and revised procedures that happened to work on my J30.
Here is the original procedure as listed in the original service manual located in the trunk and what I had found in most places online:
SERVICE PROCEDURE
While sitting inside the vehicle:
(1) Open the trunk.
(2) Close and lock all doors.
(3) Insert and remove the key from the ignition six times within 10 seconds.
(4) Manually unlock and lock driver's door once to enable "Belting" mode.
(5) Push lock button on the new remote controller once, just long enough to hear within 5 seconds of completing step 4.
(6) If additional remotes are needed (up to 3), repeat steps 4 and 5 for each additional remote immediately after programming the first remote.
NOTE: a total of four (4) remotes can be programmed to function on the same vehicle.
Now here is the revised procedure that worked for me and this is what I had viewed on YouTube. The differences are located in steps 3, 5 and 6; The full revised procedure is as follows:
SERVICE PROCEDURE
(1) Open the trunk.
(3) Cycle the ignition switch from On to off positions and fully remove and insert the key from the ignition switch six times within 10 seconds.
(5) Press and hold the lock button on the new remote controller or FOB, just long enough to hear the alarm sound within 5 seconds of completing step 4.
(6) If additional remotes are needed, repeat steps 4 and 5 for each additional remote immediately after programming the first remote.
I am still not able to program the second FOB that I have utilizing the procedure. It seems as if it’s either one remote control/FOB or the other will work at a time. However, I am just tickled to have one remote working again. If I was able to program both of the FOB's, I would be ecstatic and ever so grateful.
Larry
