Reverse positive and negative wires
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jdsetac
Car: 2015 Nissan Versa SV Sedan
I have a 2015 Nissan Versa SV Sedan, that i am installing a Garmin backup camera on. The camera has one red, and one black wire; I am assuming the black is the neg/grnd. What two wires are the pos and neg wires that feed into the one connector on rt rear in trunk?
I am well capable of making the connections, just am deficient in identifying the correct wires. I was expecting wires to go directly into each individual bulb, not into one connector :wtf2:
Silverdragn
Car: 2011 Nissan Versa Hatchback
I am having the same issue on a 2011 Versa trying to get a backup camera working when placed in reverse. I have read the FSM and saw it should be a Yellow wire. When connecting to the wire I am getting no power to the camera
used the FSM located here.
http://www.nicoclub.com/archives/nissan ... nuals.html
Maybe I just have a bad camera.
Return to “Versa Technical Discussions”
