C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Jul 11, 2003 5:24 pm
I just replaced my revhard. Cutting the flange fo each port has it's own flange will relieve a lot of warping issues. The single piece flange was probably the cause of the crack and the warping. But you should also remove the cast flashings and any sharp edges. This is where cracks are most likely to start.
You can have the crack repaired by welding. but make sure they know how to weld cast metal. It's critical the manifold be preheated, then welded with a gas welder, then cooled slowly over about a 24 hour period of time. If this isn't done, it will likely crack again as it cools down. Then, after it cools smooth out the edges of the weld. My first manifold was welded before, but it cracked along the edge of the weld. The weld itself was strong. The edge gave it a fault line tocrack along though. I anticipate my new manifold will be problem free. I spent about 4-6 hours prepping it including some heavy porting.
