reset idle?????????
All things Altima Coupe.
Beak
Car: 08 Coupe VQ
Any body konw how to reset the idle w/o taking it to the dealer. There should be a pedal trick like the ECU flash. Thanks for your help.
Beak
Car: 08 Coupe VQ
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
Beak, here's the pedal ECU reset, I am not sure it works with push button ingnition but It worked on my Z and Titan, I always did it after installing a mod or letting my gf drive for a week, lol. Make sure everything is turned off...it usually took me about 3 tries to get SES blinking using 1 thousand 1, 1 thousand 2 method
http://www.titantalk.com/forum....html
Beak
Car: 08 Coupe VQ
hey, thanks yes it does work with push button. i do the ecu reset from time to time. ive seen this before just did not know it they would all apply to the altima. i guess ill just try it.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
To reset it you need to do a series of things.
First: ACCELERATOR PEDAL RELEASED POSITION LEARNING1. Make sure that accelerator pedal is fully released.2. Turn ignition switch ON and wait at least 2 seconds.3. Turn ignition switch OFF and wait at least 10 seconds.4. Turn ignition switch ON and wait at least 2 seconds.5. Turn ignition switch OFF and wait at least 10 seconds.
Second: THROTTLE VALVE CLOSED POSITION LEARNING1. Make sure that accelerator pedal is fully released.2. Turn ignition switch ON.3. Turn ignition switch OFF and wait at least 10 seconds.Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Final: IDLE AIR VOLUME LEARNING
Make sure that all of the following conditions are satisfied.Learning will be canceled if any of the following conditions are missed for even a moment.• Battery voltage: More than 12.9V (At idle)• Engine coolant temperature: 70 - 100°C (158 - 212°F)• PNP switch: ON• Electric load switch: OFF(Air conditioner, headlamp, rear window defogger)On vehicles equipped with daytime light systems, if the parking brake is applied before the engine isstarted the headlamp will not be illuminated.• Steering wheel: Neutral (Straight-ahead position)• Vehicle speed: Stopped Transmission: Warmed-up (Drive vehicle for 10 min)
1. Perform Accelerator Pedal Released Position Learning. Refer to EC-29, "ACCELERATOR PEDAL (Should be done already)RELEASED POSITION LEARNING : Special Repair Requirement".2. Perform Throttle Valve Closed Position Learning. Refer to EC-29, "THROTTLE VALVE CLOSED POSITION (Should be done already)
3. Start engine and warm it up to normal operating temperature.4. Turn ignition switch OFF and wait at least 10 seconds.5. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.6. Repeat the following procedure quickly five times within 5 seconds.- Fully depress the accelerator pedal.- Fully release the accelerator pedal.7. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stopsblinking and turned ON.8. Fully release the accelerator pedal within 3 seconds after the MIL turned ON.9. Start engine and let it idle.10. Wait 20 seconds.11. Check engine idle is between 600-700 rpm.
and your done.
LinkNuc
Didn't I post that in a more condensed format Captain redundant? J/k Adidas
Beak
Car: 08 Coupe VQ
lol. thanks both of you. i value both responses haha
