Sdavne »
https://forums.nicoclub.com/sdavne-u146519.html
Wed Feb 24, 2010 8:29 am
I have a 1990 300zx and my clock burnt out and i went to the dealer and it was over a $300 part and you can not replace the batterie. I looked on craigslist and someone around me was selling it and it was only $20. it was very simple to replace. there are two screws in the vents and a plastic pice that u can pull off with a flat head screw driver right above the head unit. after getting of that pice there are two more screws to take out.if you open the ash tray i beleave there is another screw there too. there might be another one in the arm rest. after all the screws are out the whole unit should pull out. there is a wire connecting the clock and a screw holding the colck in the unit. pull the wire out, it might be hard to pull it out, (i used a flat head screwdriver to help this might take some time. just have pacentants. after get new clock plug back in and put all back together..
