Replacing my ABS Relay?
Mailorder
Car: 1994 Infiniti Q45
Some time ago, I made this thread:
zerothread?id=337879
Basically, my battery died again. I just replaced it and I noticed the whurring sound under my hood again.
So I guess it's the ABS relay. I avoided replacing it last time because the problem fixed itself and I had no idea what an ABS relay was. But now that the issue is back, I'm determined to solve it for good.
I assume this is my relay box and the thing I've unplugged is the ABS relay. But when I reconnect the battery, the whurring sound still comes back. Any ideas?
EDIT: I plugged the thingy in my hand back in, hooked up the battery then cloncked it with a wrench and got the whurring sound to go away. I'm shocked that the resolution was so simple, but I guess that's just how it is. I guess there was just a loose conneciton somewhere.
Modified by Mailorder at 10:49 PM 2/26/2009
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Joe has an additional 7% off sale this month. Might as well get some filters (including M1 oil filters) and other upcoming maintenance bits.
Mailorder
I just called infinitipartsusa.com they want to know which actuator needs to be replaced. He said there's three different ones. If he says there's three, is he talking about the one yellow thingy and the two green thingys on the left side? I'm afraid I can't identify the parts. I also don't know how to tell which one to replace.
Q45tech
ABS relays are located inside black box attached to ABS pump not in master relay/ fuse cabinet.
Mailorder
Updated my main post.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Mailorder wrote:Updated my main post.
Still haven't updated your profile!
You may have a failed actuator. In all your posts you do no mention brake hydraulic system maintenance nor present condition of fluid (color, freshness).
Mailorder
Updated main post again.
Also, what do I need to update in my profile?
Q451990
Mailorder wrote:Also, what do I need to update in my profile?
It's helpful to have your Year, Model, Options (like Active Suspension), mileage, and location in your profile. It really helps us to know when helping to answer questions.
Heath
CStalin
I've had the same problem, but I replaced my abs relay with a brand new one, and it's still making the buzzing noise?
Mailorder
New question. Where do I purchase a new ABS relay? I went to AutoZone but they didn't have the part. Do I need to go to an auto parts store in import specialty?
Officerwilson04
Car: i dont have specif car, i work on all kinds.
CStalin wrote:
Fri Apr 17, 2009 9:28 am
where did the relay happen to be located?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Officerwilson04 wrote:
Thu Nov 21, 2019 4:08 pm
It's several posts above, from Q45 tech.
passenger side near the firewall. small back box with no obvious markings
