Alibireason »
https://forums.nicoclub.com/alibireason-u299870.html
Mon May 09, 2022 9:48 pm
Removal at junkyard was a success. Took out the screws of the door panel, removed it. Removed 10mm bolts for window motor. Only two more remained, but hidden behind the metal attached to the large window. Given it was the junkyard I put all my weight into it and "peeled" back the metal enough to have clearance for a small 10mm wrench to fit. Once I got those bolts removed and window pushed down and out of the way I had access to the small window. I didn't bring WD40 but I did bring a plastic prying tool. I bent the S@it out of the piece (sash) that held the big and small windows together, getting it out of the way. I had to rip the rubber that holds the window. You have to peel back the rubber at the top and bottom to give the glass better clearance. Then I used the pry tool to shimmy, bit by bit, the small window towards where the large window was. Got it. Then Glass Place tells my insurance won't cover because I sourced my own glass. Ha! Called insurance (State Farm) and they straightened it out. Thanks for the tip VStar!
