Replacement Fuel Line
eric95q45
I'm going to replace my fuel pump tomorrow. I remember reading about using fuel injection hose from a regular auto parts store. Is this good practice or is the infiniti fuel line recommended? I tried searching, but there are an awful lot of hits on fuel line or fuel hose replacement. Any advice? Also what size(diameter) hose would I need once I have the pump exposed. I'd like to have the parts before I start. Thanks.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
eric95q45 wrote:I tried searching, but there are an awful lot of hits on fuel line or fuel hose replacement.
And this is bad?
Which lines are you replacing? The ones out of the tank or under the hood? Use the best quality you can find. Joe can get them to you fast. The good stuff is not cheap, so don't be shocked at the price whichever source you use.
eric95q45
I was going to replace the ones out of the tank.
