Ryantzer »
https://forums.nicoclub.com/ryantzer-u223805.html
Fri May 13, 2022 10:08 am
Keeping it R12 was my original plan - I know from experience that an R134 conversion typically results in slightly less cold a/c, and the summertime temps here in Phoenix make you want every degree of cold air the system can provide. I spent nearly $100 on eBay cans of R12, which had to be evacuated when we later determined the original condenser was almost completely clogged. At this point I'm going to have to replace the compressor which has now seized up, so I've picked up a 4 Seasons kit that incudes the compressor, expansion valve, and dryer, all supposedly R134 ready. The condenser is the last piece of the puzzle, and if I can source one that's a more efficient design than the OEM R12 condenser I will be content knowing that I've done everything I can to make it perform as well as the original R12 system.
