Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Sat Nov 15, 2003 1:30 pm
Decided to do the valve cover gasket replacement myself (didn't have the extra $500 to $750 for labor).
I did the passenger side today. I unplugged everything, and tried not to remove the fuel lines, but eventually had to. The front one, from the filter was a snap, but the rear one was under pressure, and I had to plug it, to keep it from draining the tank. I dripped some fuel into the engine, while getting to rocker cover off, but it was aver little ammount, and I didn't think it was a big deal, really.
Finally got the cover out of the engine bay, and cleaned it up, and put on the new gasket. I then took a brake to eat lunch. I plugged everything back in, and did a test run, before doing the driver's side.
I started the car, but had forgot to re-plug the MAF. I plugged it in and re-started the car. It seems to be running rough. Like may be the even cylinders weren't firing.
I checked all the connections of hoses, and wires, and they all seem fine. I unplugged and re-plugged the Fuel Injector wires, and there was no change.
I drove the car around the block, and it seem like I have a 1.8 litre engine. It barely moves.
I disconnected the battery for about 20 seconds, to see if that would reset the ECU. (I really don't knkow much about the ECU).
I am planning to do the driver's side, tomorrow, when my headache is better.
I have spent the last hour on this site, doing searches, but have found no help.
I recall a mention of the fuel pressure, and a thread with someone having the same driveability problems.
I do not have a manual, and do not know how to check the ECU cotdes, so a little help there would be nice, too.
I feel like it is something simple, but don't know where to start.
Can you guys give me some ideas?
Thanks for the help!:help :help :help :help
I really am a good DIY mechanic, but this enigne is not your normal engine. I will master the Q, eventually.
