2012 Quest SL. Got a code for the stepper motor in the CVT. Bought motor on eBay and filter and gasket locally. Aisin NS-2 fluid came today. Pretty easy R&R. I had disconnected the negative battery cable prior to work.
When the code popped up I had basically low/1st gear and reverse. Now I have nothing. It doesn’t go into any gear.
Did I do something wrong? I’m going to drop the pan and check that the plug is installed correctly on the motor. Could I have a bad motor?
Thanks.
