removing the flywheel
A home for 1983–1989 300ZX owners!
kelloggman
Car: 73 240z
whats the best way to remove the flywheel(az-bum dont need the answer you gave last time plz)
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
SEARCH!
Ha, somebody had to do it. Anyway, an impact wrench is your friend on... pretty much anything that wants to spin while you are trying to break it loose.
XJared
Car: 06 Titan, 83 Z, 10 Z
remove transmission, remove pressure plate and clutch, remove flywheel, rinse and repeat
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
kelloggman wrote:whats the best way to remove the flywheel(az-bum dont need the answer you gave last time plz)
Remove the bolts and pull it off.
What the hell dude? Are you retarded? What is so difficult to understand about this?
If you know I'm going to respond with this reply, why don't you make a smarter post?
kelloggman
Car: 73 240z
hahah yes im retardedand ill try adding more info next timethe problem i was having was the flywheel kept moving the crankshaftat the time i was doing it i was getting flusteredbut its off so thanks for the help.
i did search nothing came up. anywho torch wrench sounds like something i need to pick upthanks
AZ-ZBum
kelloggman wrote:hahah yes im retardedand ill try adding more info next timethe problem i was having was the flywheel kept moving the crankshaftat the time i was doing it i was getting flusteredbut its off so thanks for the help.
See? That would have been good information to know. If you're having a problem, explain why you're having a problem and what you're doing when the problem is occurring.
kelloggman
Car: 73 240z
yea i agreeagain flustered and hit post too sooni tend to do that alottry to work on it again thanks for the help
XJared
I did not understand your issue at first, so you can't make the crank stay still. Option 1, use a breaker bar on the crank bolt, lock it against a frame fail, loosen all the flywheel bolts. Option 2, get a solid 1/2" impact wrench.
Return to “300ZX (Z31) Forum”
