Removing front bumper ?
Drift
How many screws and where are they located? TIA
Anand
Car: 95 Nissan 240SX
what year is your car?..
daniel240
Car: cars/motocross
Hey man im glad you asked this question, im taking mine off next week to paint it. i have a 96. i would like to know if anyone has removed theirs and if they have any tips!! any help would be greatly appriciated.
Anand
OK.... removing the 95-96 bumper is really easy.. I do it within like 15 minutes... this is what you need to do:
1. remove the headlights... that should be pretty easy2. remove the center grill3. there are 2 bolt/screws uneder the center grill that you need to unbolt/unscrew.4. under the headlight there should be a bolt/screw that you need to remover (one on each side)5. you need to remove the fender lining in the tire well...5. if you don't want to remover the whole thing.. you can just loosen the side that is right next to the bumber... front part so you can slode you hand between the fender lining and the bumper...6. there is one bolt that will unscrew/bolt downwards close to the outer edge of the bumber... closest to the wheels (one on each side)EDIT: 7. there are these 2 little screws one on each side that are horizontal and you need to unscrew those as well so all together 6 bolts and 2 little screws... you can't miss them though ( i updated the picture)
and you are done... the bumper should just come right out... just unclip the lights...
I am attaching an image that should give you a little idea of there they are located and how to get at them:
(i'm going to try to locate a real picture of the bumper and point it out)
Anand
I found this one and so you can get a better idea of it...
BTW I drew those arrows and the bolt points so they could be a little off but not bby much at all...
Megaseth
Car: 2002 Pathfinder SE
If its a S13 model. good luck, it took me a day to get mine off.
BuudWeizErr
hah.. on an s13, that is a PITA.
there are like 14 bolts holdnig it on, and the ones at the top on the sides are HORRIBLE. you better have a few extensions, and some wrenches. It's a pain, it took us like 2 hours to get it off, and 4 hours to get it back on while trying to hide an intercooler behind it.
Just another 240
ah ****, i have a s13, and i'm planning to take it off soon..aww man..
matt240det
my s13 took like 2 hours or so to take off, extensions and universal socket help greatly...let me tell you how many bolts aren;t going back in...lol
SilviaLuvr
Car: shopping for parts going to school to become a massage therapist
Megaseth wrote:If its a S13 model. good luck, it took me a day to get mine off.
a day, what the f*k where you doing...? j/k it took me about three hours to take off. the bolts deep inside the bumoer that connect the bumper to the fender are a ******!
daniel240
Car: cars/motocross
Thanks alot BLACK240 that is what i needed to know, that will help me out a lot.
alexar55
Try taking S13 fenders off, it's 10x worse than the bumper
Megaseth
HAHA, ok so it didnt really take a full day, just seemed like it cause i didnt work on it straight, kinda off and on. but it is a b**** to remove. the side bolts are the worst, the ones that connect up to the fenders. altogether there are around 22 bolts that hold it in place. have fun...
Drift
I have an S13 Model.
Mike09
gl i guess. Hey does anyone know if this bomex bumber will bolt in easy on an 89'. It's Part # uad 406
http://www.bomexaero.com/bomexusa.html
Just another 240
if i hit my bumper against another bumper and now mine is slanting off in a way. would taking it off and putting it back on OR buying another bumper and putting it on fix it? i'm sure the internals aren't mess up.
SkillaSX
Car: Cars, Sports, Women
I know this is an old school thread but, can anyone illustrate the location of the 14 bolts on the s13?
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
I took mine off over the winter, so let me try to remember. I had to do it twice, so I got pretty quick at it. lol
rousie13
You have two black screws in the fender well holding the two plastic bumper pieces on. then theres double stick tape and two snaps holding the piece on. Pull those plastic pieces off. Atleast I think you have to take these off, but maybe you don't need to. Pull the inner fenders out, so you can get at the bolts holding the bumper and fender together. Theres I think three bolts on top and two on the bottom holding the bumper to the fender. Then theres 4 bolts holding the top(by the radiator). There are also snap screws on the bottom by the radiator holding it in. There is a metal piece underneath the bottom of the front of the bumper that needs to be removed. I think I named all of the bolts and locations, but not positive. I hope this helps you. Pop the lights up when you try to pull the bumper off.
ftrs13
Car: KATs
haha, I just tried to take mine off today (s13) to fix a little dent, I removed most of the bolts, and when I got to the side with the damage found that the bumper fender screws were folded to the point where I couldnt get to them. S***!, anyway, I ended up just putting everything back together for now and I will cut them off when I have a little more time (a couple days) and all the work back there that I have to do.
anyway, I must agree that it is a huge pain!
