Removing Emblems
Flagship-Q
Car: 1992 Infiniti Q45
I'd like to remove the "Q45" from the rear deck spoiler and was wondering what was the best method to do this. I like the idea of nobody knowing what I'm driving or how fast it is!
CJQ45
Car: 1997 Q 77k 03 Maxima GLE 19k
YOu can pry them off gently and use a sharp blade to scrap the glue from the panel. Do this very carefully - its easy to damage the paint.
Once you remove them - there will be two holes in the panel per number that act as holding points. You'll need to fill them with some compound and paint to match the same color as the back. Its a PITA to do the entire thing unless you dont mind driving with holes in the trunk - I would.
CJ
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
when i took my emblems off i just used a screwdriver however i didnt care about the paint. You could take a piece of plastic, say from a plastic bottle, cut it out, and wedge it in between the paint and the emblem. They have this adhesive foam stuff and thats what you need to do.. There will be a residue left on there and then just take like some rubbing alchy to get the goo off....
qship96
Car: 1996 Infiniti Q45
use waxed dental floss-saw in between letters and paint-lubricate with wd40 or detailers spray as you go-no holes behind emblems on the 90-96q-just adhesive tape.
elwesso
2007 BMW M Coupe
qship96 wrote:use waxed dental floss-saw in between letters and paint-lubricate with wd40 or detailers spray as you go-no holes behind emblems on the 90-96q-just adhesive tape.
Wow great idea, id never have thought about that...
What did you use to get the adhesive foam off...
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
thats how i do it BEST way smoothe as silk
a little elboe grease at first then wd40 or there is acommercial spray they sell at stickercity.com
the rear center emblem is 2 screws and tape
CrimsonQ
Car: Purple People Eater
or check this thread in infiniti mechanic, i removed mine as wellhttp://forums.nicoclub.com/zerothread?id=1128
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
WD40 on paint is not a good idea. Go to the thread.
ferran586
I have taken off many badges in my time and I find the best way to do it is to use a heat gun (hair dryer will suffice). This will loosen up the adhesive and then use fishing line/dental floss to get the badge to come off. You then can use a adhesive remover that is safe for paints to remove the remaining glue.
jamesmost
i have used goo-gone on enamalhave not had any prob w wd-40 do wash after w/soap
tkd_q45
Folks on merecedesshop.com use heat guns to remove their emblems.
Negrodamus
Car: FX35
I used my wifes blow dryer and a old credit card to get the glue residue I use an eraser from a good pencil or you can use a good wax I used 3m rubbing compound that removes blemeshed and that works cool since is a little more course than a regular wax
