cmfireman »
https://forums.nicoclub.com/cmfireman-u41874.html
Tue Jan 15, 2008 6:47 pm
So I've been playing around in a band here lately, and we're trying to get some tracks down for a demo CD.
We have the following setup:
Samson 8-channel pre-amp mixerPeavy PA systemHP desktop with a factory soundcard running Audacity recording softwareOne condenser micOne dynamic mic
After much trial and error, we have got a good acoustic/clean, bass, and drum sound by miking the bass amp/half stack/drum kit with the condenser mic in the middle of the room.
We record the music all at one time (bass/guitar/drums), and then have the vocals layered on top of the music using the dynamic mic so we can adjust the volume properly.
Everything sounds pretty dang good for a broke garage band up until this point.
The problem is getting a good distorted guitar. We have a crate half-stack, going into a generic multi-effects pedal that sounds just fine live, but when we record with distortion, the guitar just sounds very weak and airy. It has no punch.
My idea is to separately mic the cabinet with the dynamic mic, while the condenser mic is picking up the drums and bass in the middle of the room, but I think if I do this I still won't get the needed thickness because the condenser mic is much more sensitive than the dynamic, causing it to pick up the same noise that I'm hearing on the playback.
Another option I have considered is running the amplifiers line-in directly into the mixer to receive the signal, but while we're playing the guitarist and other musicians need to hear the guitar track, so this leaves me wondering if the signal-in would cover up what the mic is picking up, or if you would hear both signals while listening to the track. I also need a way to record the signal using the line-input and hear the sound through the cabinet simultaneously.
The main objective is to have the band play all instruments together, and get the highest recording quality possible.
Does anyone that has some recording experience want to lend a helpful hand/ear? I'll try and get some samples up tomorrow.
I'm banging my head against the wall trying to get the desired sound.
Modified by cmfireman at 12:10 AM 1/16/2008
