Smileysauce »
https://forums.nicoclub.com/smileysauce-u260077.html
Sat Jan 02, 2016 4:19 pm
First, I like to apologize in advance, I'm new to posting in forums so if there is any conduct or etiquette that I didn't follow please forgive me.
I recently rebuilt my VG30DE from the ground up and excluding the headers I installed, it's completely stock. I had my heads and valves rebuilt as well and I have new pistons, piston rings, and injectors. Let it be known that this was my first time rebuilding an engine but I was extremely careful with labeling and taking pictures. My car is a 1990 N/A engine.
Now it starts up but idles rough and I've got white/gray smoke coming out of the exhaust. The longest I've had it running constantly was about 5 minutes but my father helped me do this project and from his experience, he said it's normal to have that smoke out of the exhaust for a while. All of this is to just give a little insight as to what I'm looking at.
The big issue I'm having right now is that if i try and touch the gas, it starts to sputter out and die. According to my father who was standing behind the car when I touched the throttle, it started to kick out what he and I both believe to be fuel and I will further say that I can smell fuel as if it was running rich.
So all in all, I need help trying to figure this one out. CAS is the same, MAF is new, PTU is new, and the IAC Valve is new.
Could the CAS cause something like this? Or is it a problem with the injectors or even the timing?
Thank you,
Smiley
