Rebuilt engine. Checked Timing 3 times.. turns but wont fire
trulyphly710
I have a 92 240sx . So it was about a year and half ago. My car had fluctuating idles when i was at a stop. going anywhere between 100 RPM up to 2000 RPms constantly going up and down. And then one day, when i went to drive it, the idle fluctuated soo much that it cut off on its own right away.
So i decided to rebuild the KA24DE block. i took the block out and rebuilt it with the help of mechanic friend. I pretty much did everything and he walked me thruogh the more complex parts of the rebuild. I figured the the main cause of the idle was the timing chain so i checked the timing chain about 3~4 times before i put it back together.
Well, when i put everything back together, the car would turn but it didn't seem to fire/start. I could smell my fuel flooding the injectors though. the distributor, cap and all of that were replaced. I messed with it for about a month messing with the ignition timing and everything and nothing seemed to change.
What could be some possible reason for this? Could the IACV cause a car not to start or a vacuum leak? I think i "might" have mixed up the vacuum hose on the block between the firewall but i'm pretty sure i got it on right though since its molded hoses.
Could it be an electirical issue here? please help as i want my car back up and running again! Thanks
Modified by trulyphly710 at 11:15 AM 5/11/2009
Modified by trulyphly710 at 11:17 AM 5/11/2009
whitenight639
Car: Nissan almera N15 GA16DE
i dont know anything bout the 240 but have you checked the MAF sensor?
you mentioned its fuel injected so i imagine its electronic fuel injection with an ECU.
trulyphly710
never checked that. How do i go about checking that? or do i just clean or replace it?
Thanks
signals13
Car: 1994 nissan sentra, 1992 nissan 240
have you checked your timing i.e. distributor and crank? is it setup correctly dissy at 1st piston tdc? that was my problem with my motor.
