pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sun Feb 13, 2005 12:54 pm
Hi,
So, I got myself another ca18det but this one is RWD, Got a good deal on it $200 bucks as it had very low leakdown test results. I will convert it to FWD.
So, I am rebuilding it to replace the current FWD ca18det in my car due to bad rings(lots of blow by) and headgasket after some serious abuse which lasted for over 5 years.
So, I took the new motor apart and I am in the process of rebuilding it, got new rod bearings, main bearings, oil pump, water pump, idle pulley, new rings, I am keepin the stock pistons as I know they handle the power that I want. HKS head gasket 1.2mm, arp headbolts, I ported the head (Thank God for Dremel tool), but I will be sending it to the machine shop to get a 3 angle valve job done on it.
I painted the block and the oil pan black, but then I got a black metallic paint which I sprayed the block, hopefully the heat won't make it peel off.I thought I share some pics,
When I get the head cleaned and machined, I will get some more pics.
RafiPULSAR GTR
