Hmmm. Well you should search. Are you gonna auto-x it, drag, street, etc. Dont forget suspension and stuff too. Right now I have AEM short ram and 3" exhaust. Next im getting HS Headers and a new cat. converter. But after that Im gonna get some springs, struts, rims, Z32 brake upgrade, etc. Then Im gonna do a full service of the car to get it in tip top shape before i do anything else to it. Then Ill probably get new pulleys, cams, gears, and ecu, and other small things. Then Ill work on the drivetrain and stuff. Ill get new clutch/flywheel, driveshaft, shortshifter, etc. Then, hopefully next summer I will begin saving for my NSport turbo kit. Ill get new pistons, rods, and other internals before i get the turbo. And, God willing, Ill have the turbo done by the summer 2005. There are other little things Ill need to get along the way. Just an idea. Other things like radiators, bigger throttle bodies, fuel, and ignition all have to be in mind too. Its best to pick out all the things YOU want. Then research prices and set up the things you want into steps or phases. Then you can keep yourself accountable by seeing how youve come along with your schedule.
I am currently ahead of schedule
