...See the old bushings that came with the bar were quite hard and worn and deformed. I had planned to use flat washers to compress them (ala Q45tech) till I could get a set. I ended up changing all the concave washers (except for the couple that are fixed in place) because the new bushings were much beefier with a larger circumference and would not seat as well. Since I can get bushings so cheap, I can now experiment with different degrees of bushing compression and not have to worry too much about splitting them.
Here's early in the game when I was still experimenting with flat washers. I now have no need since the new bushings are so thick, I could barely catch the nuts. As a matter of fact, I had to slice 1/8” off the two top bushings to catch the nuts. There was no need to cut the bottom bushings.
Old and new side by side. Notice how much longer the OEM link bolts are. I used the OEM bolts and changed everything else. Note bushing size difference as well as seat washers. I also put the box in the shot for anyone who wants to try this. Just go to Napa and ask for the number on the box.
Close up of the box for all you Stevie Wonders and Ray Charles out there…
Pay close attention to this one. Getting the bar into place took like two minutes. I fed the bar into position BEHIND the diff, then slid it forwards to it's proper position up near the drive shaft flange. There was no need to mess with the exhaust and even though I took off the driver's side rear tire, I probably could have left it on where this was concerned. Here's how you start the bar off...
Now I have moved it forward to it's mounting location. Quite simple…
Driver's side main support bushing…Connected ALL nuts and bolts loosely before tightening anything. I also sprayed all the holes with WD-40 as they had never been used and were quite cruddy.
Please note that the car is supposed to be sitting on all 4 tires for the end link's to line up properly. With car on jack stands, I jacked up the lower control arms instead providing the same effect and allowed me to stay under the car.
Here's with the bushing in place. This is a cut bushing..I ended up loosening the top nut and re-centered the bushing you see here as it was slightly off center. The washer below it is fixed and is smaller than the new washers making the larger bushing harder to seat. Maybe I should have sliced a little more off the bushings and sat a new washer inside the fixed washer but I was thirsty and my friend Bud said screw it... next time.
Top bushing (cut)
All done… bad pic but I wasn't jacking the car up again for you slackers…
'Bonus for DIY... while underneath, I discovered a bubble in the driver's side tire on the inside. The fronts are new and I just replaced the pass side rear with a new tire (yesterday) after picking up a sharp object which tore a hole in it. These are 18" sumitomo HTR + and I was able to get it for $57 with my road hazard protection. Now with the bubble in the remaining tire, I'll have brand new set all around. (gonna hit em with the warranty/road haz again). I'm so devious!!!
Drew
BTW, I haven't test driven yet so I'll post my observations in a day or two.
