rear suspension clunk over bumps
robomatic12
Car: 1990 300ZX TT
It appears a lot of people have problems with a clunking noise coming from the rear of the cabin when going over bumps. It sounds like it is coming from high up and not an "outside" noise. I have jic coilovers installed. Is there anything you guys have found to solve this clunk?
So far things I'm going to check:-Retighten center coilover nut with impact gun-Sway bar bushings (but noise sounds higher?)-Spring rattle?
Modified by robomatic12 at 7:11 PM 2/19/2010
tmeyer29
Car: 1990 300zx TT , 04 Yamaha R6
check all bushings
car nut
Car: GT500.
tmeyer29 wrote:check all bushings
robomatic12
Car: 1990 300ZX TT
it's not something simple as a bushing. I need people who have coilovers for their input, its something at the top of the coilover that's making a noise.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
Alot of coilovers are noisy you go to a pillowball mount and have metal on metal as opposed to the rubber cushion with shocks. Them also being stiffer though you will hear things you didn't before from the car. Hard to give you much help without hearing it though.
