Rear Subframe brushing
A forum for the Nissan Quest... minivan lovers unite!
zaferdie
Dealer is asking to replace Rear Subframe brushing
Quoted 3800 for this
Anyone has any idea
When I look at google it says repair ranges from 250-500
far raf
Car: 2005 Nissan Quest SE (standard? simple? edition - i.e. nothing special)
What on earth is brushing?
zaferdie
Sorry not brushings but bushings
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
Go somewhere else. This can be done at any repair shop for much less than dealership.
What is the reason you need them replaced?
far raf
You mean, stabilizer bushing? That's an easy DIY job, so should cost no more than a couple hours worth of labor. The dealer is a crook.
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
Likely not sway bar bushings, more like any plate or substructure under vehicle that holds all the suspension in place. I'd be seriously questioning that as those commonly need replacing less than actual suspension bushings. Often never. Unless vehicle is up north in really salty areas.
expensivetofix
Car: 2008 quest 3.5 se
i`m "up north in a really salty area" (NH) and havent had any problems of that kind. The swaybar bushings where a real booger though. Describe for us whats happening and when so we can get a better idea.
far raf
I am in the even saltier area - Toronto, Canada. And the van is holding up surprisingly well, except for the completely rusted through oil pan, which I replaced last year.
Not even having typical subframe rot where AC drips on it.
Return to “Quest Forum”
