MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Fri Oct 13, 2006 12:20 pm
The speaker screens are screwed in from beneath the rear parcel shelf upholstry, which means you can't just pop them off to get to the speakers--you have to remove the whole rear shelf. You will need to disconnect and remove the Center High Mount Stoplight and it's plastic surround (and maybe the mounting bracket if it's in the way). Once that is out of the way, the parcel shelf upholstry should come up. It's held in place with 5 or 6 plastic clips along the forward edge. Pull up and they will break free (occasionally on the wrong end...you may want to stop by the dealer to have some replacements ready--they tend to break). Once those clips are free, lift the forward edge and slide the shelf forward. It should come free. You'll have access to the speakers at that point. When the speakers are replaced, make sure all the plastic clips are back in their slots on the shelf, then slide the rear edge back into it's pawls. Drop the forward edge and align the clips, then smack the shelf above them to seat them.
It's a pretty simple process, but breaking the plastic clips loose for the first time can take some effort.
