gwoods wrote:I think its a 3 hour job.
I paid a shop $600 to swap my 3.55 gears in my Hemi ram for 3.92 gear and a trac-loc limited slip. The reason for 3.92 vs 4.10 or 4.56 is in the hemi ram 4th and 5th are overdrive gears and with a 28" tall tire and 3.92 you are just finishing up 3rd gear in the 1/4 mile. If I had 4.10 or 4.56 I would need 4th gear to finish the 1/4
Or you could have just raised your rev-limit a little to compensate for the faster revving
DJ - It took me about 2 1/2 hours. I'd expect 2.5-3 hrs is pretty normal assuming you are using jack stands like I did.
Loosen all the half shaft bolts first, then the drive shaft bolts. The 3 mounting bolts are easy to deal with.
Dont forget to take off the rear sway bar bushing/mount bolts.
GL, put up a review.
BTW, $170 is a killer deal for what you got. I sold my open 3.3 FD diff for $200 + shipping.
Make sure you have new fluid to do that at the same time.
