diitto »
https://forums.nicoclub.com/diitto-u55539.html
Tue Mar 06, 2007 7:03 am
Thanks to all, especially Telcoman... What you report is precisely in line with what I am now almost 100% sure is the case, that the L to H span represents more like two quarts... Bummer as that means my oil consumption is half of what I previously thought it was when I assumed that difference was one quart... I have decided to ban the idea of paying attention to span and instead strive to keep the oil right at the H mark all the time and record over time how much oil I have to add to keep it there... If you do that, you don't care what the span is because you're not using that at all in your measurement... The only reason I didn't do that before is there is always the possibility of overfilling the engine if you aren't really careful but since I am just that, careful, I have decided to add oil slowly over a day or two to get it right at the High mark and then measure the oil usage over time that way... Thanks for the input...
Now, does anyone have dealer or Infiniti information about what Infiniti really considers to be excess oil consumption???? I have certainly heard words to the effect of under 1000 miles per quart is definitely a problem but what about something more like what I think I am seeing now that I have halved all my previous readings, which would be about 1800 miles per quart??? I don't mind adding oil... I just want to know if I have a defective engine while it is still under warranty.... I currently have 6500 miles on my 06 G35 Coupe, 6MT... Any input on that would be much appreciated... thanks... bob...
