Q45tech,
Thanks for confirming my thoughts about the third and fourth gears.
When I tried to order differing pinion teeth numbers, I had a bit of trouble. I assumed that the part number would be the same except for the last two digits, which appear to represent the number of teeth.
When assuming this, the pinions I got back did have the teeth number that matched the part number, but were different in width. This is why I had to make my own.
As Chally can probably vouch for, parts are very expensive for the Q45 here in Australia. The cost of making a pinion gear in the end was actually cheaper than buying a Nissan part, as absolutley everything has to be imported from Japan.
To my knowledge there are less than one hundred Q's in the whole country, so Nissan Australia does not stock ANYTHING.
Chally, correct me if I am wrong on the the number of Q's you reckon there are in OZ.
Anyway, I think the perfect solution may be a level 10 Computer Performance Upgrade
http://www.levelten.com/products_2.htm
http://www.levelten.com/computer_pts.htm
Q45tech, thanks for all your help here. It has helped me reach the decision to sell the 51X65 and buy a 51X79.
Cheers
AGM
