MesaGuy »
https://forums.nicoclub.com/mesaguy-u266788.html
Fri Oct 07, 2022 6:40 pm
RE4F04A/RE4F04V and
RE4F04A/RE4F04W are both equipped with the VLSD.
The Original Transmission for you vehicle is listed on the VIN plate in the engine compartment back wall, behind engine, driver's side.
Its like the 3rd or 4th line down.
In both cases, the Viscous Slip unit is totally sealed (from other parts of the transmission) and contains a heavy weight viscous oil (much thicker than ATF). The VLSD is essentially totally indepdendent of the ATF you are putting in the remainder of the transmission. The VLSD is not user serviceable. You do not replace the Viscous Fluid ever. In fact, the unit cannot be serviced by mechanics either, just replaced as a unit. (The unit can be replaced, or substituted with other after market options.)
I believe you can even put the VLSD unit into the the standard "B" transmission, but you would have to replace the entire Final drive assembly (e.g. the Differential, the diferential pinion, side gears, and drive wheel. The VLSD version has a larger donut hole in its drive gear, and the differntial itself has 4 transfer pinions on a holy-cross mount, whereas the stndard just has a 2 (a top and bottom) on a pinion shaft. So the VLSD in additionl to having the LSD, also has 2 more transfer gears to distribute power better, and prevent warping.
The VLSD is better on the track, on the road, and in snow.
Most Canadian version of the Maximum have the VLSD (because of SNOW), and very few USA Maxima's have the VLSD. The i30t Infiniti was the only USA automatic, except for: 20th Aniversary Addition Maxima's, and special order SE Automatics that special ordered the VLSD.
Some (few) 5mt manual SE's also had the VLSD. All GXE, all GLE, and most SE automatics were open differential in the USA. Most SE manuals in the USA were open differential too. But a some SE's, and 20th Anniv. Addition Maximas had VLSD, as well as i30t (only automatic).
