RC engineering injectors anyone?
JDMSIL80
Would these bolt-on perfectly since they are made for 90+ DSM, top feed, low resistance:
http://cgi.ebay.com/ebaymotors...wItem
One thing Im concern though is my Mine's ecu was tuned for 444cc, would my car run pig rich with these injectors? Or is it safe to run richer?
Thanks!
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Just an FYI, RC, Lucas and Precision Turbo get their injector bodies from Delphi. So any of those will work. 550cc injectors for a DSM on ebay.... $209.
JDMSIL80
Thanks for the great info.
Ideally I was hoping for some brand new 450cc, since my Mine's ecu is tuned to work best with 444cc.
Is it safe to run richer with the 550cc?
Dattebayo
Your ecu will not work with the 550's. As I was told, "you might be able to idle, but then when you hit the gas it wont run".
Coldspawn
c-rad wrote:Just an FYI, RC, Lucas and Precision Turbo get their injector bodies from Delphi. So any of those will work. 550cc injectors for a DSM on ebay.... $209.
That does not mean they will work the same. I have tuned most companies injectors with the same program. There is a difference. Some injectors will not idle around 14.7, they want it richer (dwell time). We are talking the same CC. The bigger the injector gets, the worse the problem gets. RC injectors are great injectors, worth the money if you want a smooth idle and light throttle.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
look for lucas/PTE injectors from importblowoutsales or somthing like that, hes got them for 205$ thats what i have sitting in my modfied fuel rail, i had to drill out the rail to get them to fit in it.
JDMSIL80
I better fine myself a good set of GTR or DSM injectors then, thanks for the headsup!
2BN_S13 wrote:Your ecu will not work with the 550's. As I was told, "you might be able to idle, but then when you hit the gas it wont run".
c-rad
Never said they performed the same. I said the injector BODIES were the same so physically they are the same dimensions so they will all fit.
CA19DET
i had to modify my fuel rrail for my RC Eng, 550's to work.. dont know if they make two designs, but i had to open up the ID for the hole for the injector on the rail
float_6969
was it the injector that was too big, or the injector with the O-ring?
Coldspawn
From a another post, c-rad wrote:brand new dsm 550s... $209 off ebay. And FYI, RC, PTE and Lucas all use Delphi injector bodies. Don't be fooled by name brands.
They will all fit, there is difference. It just matters if you can deal with the different to save money.
That is all.
float_6969 wrote:was it the injector that was too big, or the injector with the O-ring?
Thats proabably what he is talking about. The inlet OD is about the same on them.
CA19DET
injector with o ring.. i still feel i may be getting a leak from one of them, we may have over borred them, a custom rail will sort that out of course.
turbo_lover
Car: 240sx
it will be safer to run rich, but you will make more power running lean. even though your nowhere near lean lol get them , then re-tune the ECU for 550cc's:)
