rb25 swap
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
datsun-aholic
Does anyone know how easy and what it would involve technically to swap a rb25det into a 620. i know the gyst of it but i need to make syre that it will work first. has anyone done it before for street purposes? i have seen the yellow drag truck with it in there but iam aiming to make it a street/ drift truck.
PEZi
yeah.. .you can make it work
the basic idea behind it is to use the RWD transmission... and then get a custom drive shaft and motor mounts... probably transmission mounts too....
depends on your technical know how... but really not the hardest thing ever
datsun-aholic
ok so then my other question is, i obviously want disk brakes all around, so would it be better to swap the rear end from something like a 510 or a 240sx?
PEZi
that all depends on what you really wanna do... you can make something like either of those work... or if you want to keep it solid rear you can do one from a Jag or something...
Return to “Datsun 620”
