Zkyline »
https://forums.nicoclub.com/zkyline-u254757.html
Mon Aug 31, 2015 11:48 pm
Not sure what happened to the pics, but basically, use a paint pen, coat the highest ridge on the flywheel, slide it up to the crank to where it rubs, remove, check the high spots, grind. Repaint, recheck, grind some more. It will be the edges of the oilpan, and the rear main housing. There is a LOT to clearance.
If someone were to take this "white bunny" setup as tried and true, and to attempt to bolt a D21 flywheel to A RB motor without doi.g any clearancing, it would be disasterous. I think the rear main housing would shatter into pieces just from bolting the flywheel on.
So PLEASE, DOUBLE AND TRIPLE CHECK YOUR CLEARANCE TO THE REAR MAIN HOUSING.
