Couldnt find the fitting I needed for oil feed from the block, factory is banjo with M12x1.25 bolt, so I drilled a m12x1.25 bolt out, and welded a -4 fitting on for my feed line.
Also couldnt find divided t3 spacers so I welded some dividers into some undivided spacers
And to adapt my MAF to the 4" holset inlet. I made this out of a 3-4" exhaust reducer, and welded a 5/8" heater hose fitting for my pcv hose
