RB20DET in my 720!!!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
bandytZ24
Car: '85 720 Pickup Z24
Just love being outside the box!!! This will be my first build that wasnt all bolt-on or somewhat easy. This truck has done great for me, hell only paid $500 for it back in 2010, fabbed 4" drop blocks for the rear, and turned the torsion bar all the way out in the front, and it has a Weber 38carb, with a 10PSI fuel xfer pump from an International ProStar for a fuel pump and after all this time finally put new tires on it, Something about the 8plug system that bugging me. Dont get me wrong its still a whole lot of fun to drive. But, for the amount of time and money I would put into the motor and transmission to get 200+ HP out of it. Found a decent RB20DET, wanna put in my 720!! I'm not worried about the fab work thats needed, its obvious theres not enuff room, so Im gonna make room, hell my floor has holes in it anyway, makes sense just to do this, to me anyway. So, any thoughts on where I can get a gauge cluster that will work with this engine?, do I really need to upgrade my fuel pump?, what would be an Ideal rearend for this application...
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
carb'd 720 have no baffling in the gas tank.
So switching to an EFI tank (late model 720s had efi) would be a good Idea.
For gauges I would just say make your own set up, but I am guessing an R32 or 240 cluster could with talent fit in a 720, or you could just try to splice what little body harness you have into the ecu and try and just replace the tach for DOHC.
I really want to see an RB just sitting in a 720 just to see how crammed in it is.
Fuel pump upgrade definitely...Fuel cell or bed mounted tank of some sort? might be an Idea later down the road, if at all neccessary.
You might also relocated battery, also not sure if necessary, especially with the stock intake keeping it to the drivers side.
PEZi
Relocate the battery for sure.... and anything else you feel comfortable moving out of the engine bay besides the engine!
bandytZ24
Thanks fellas, how about the rearend, any ideas???
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
You will need to cut the fire wall for it to fit. No problems with the turbo though. Drive shaft will have to change also. I cut my tank and installed the complete pump from a sentra N16. As for the gauges I installed the dash (the complete dash) from a B 12 sentra. The tach is no good as its set up for four cylinders. Have fun. Will post a pic of the tank tomorrow.
bandytZ24
Cool, thanks bruh.
My720LoveMyAe86
Car: 1985 Datsun/Nissan 720 diesel
1987 Toyota Corolla Ae86 ITB
1987 Dually Nissan D21 v6 HD
1984 Datsun 720 Z24 dually
you are going in a HOLE and a BIG HOLE of money ..
nothing fit on the truck for the RB20.
GOOD luck and i will looking on ur post everyday ;)
try to fit the r34 gauge in a custom dash :P 10 k RPM gauge FTW!!!!
breadbox
89 Koop
84 720 4x4KC
I want a hole too. I need to find a cheap short block soon.
Return to “Datsun 720”
