silviasgp06 wrote:what mounts are you using? I cant really tell you motor looks as far from the radiator as mine but it doesnt look like you have a koyo rad. looks like there might be tension on that line. looks like that might be a stretch for some other mounts that sit farther back.
I'm using TopHat mounts. I know, FTL. And I have a 3-inch thick radiator core so the pics are slightly decieving.
There isn't tension in the line. It is actually slightly compressed to get it to curve.
If the hose ends don't reach with your setup, just send the line back and I can give you a longer one. Not a big deal. Another option is to send one fitting uncrimped and you can cut the hose to the exact length you need with a razor knife. Then, have a local AC shop crimp the hose end on. You just have to make sure to mark the alignment of the hose end on the hose and line up the marks because it will not twist once it is crimped.
