RB----->A/C
240z4u
Car: '95 Nissan 240SX
Darius wrote:hahahaha I am even storing the box that you sent that stuff to me in too! I had the shop measure all that stuff up but never got the solidworks files completed.
I can take a hint. I'll get back on this :bowrofl:
Nah dude, its no big deal at all honestly. I just thought I may have had what you needed. OTOH I could just find a zenki condensor as we had discussed. OTOOH (on the other other hand) I am lazy and may never get around to finishing my A/C installation :rotfl
marshallpre1
Car: 2004 Infiniti G35 Coupe
Guys, I'm picking up my first s13 RB25 swapped car and it doesn't have A/C. I just need some clarifications parts I need for easiest installation:
1. RB25 Compressor (can I get away with an RB26 or RB20?)
2. KA condenser (can I get away with any other one?)
3. Custom lines
The car I'm getting still has all of the A/C wiring installed and running an RB25 ecu and harness. Would I need to pin the harness for the A/C input into the ecu, or is A/C completely separate system? I don't have the car yet, so I'm just looking for some clarifications.
Thanks,
Jeremy
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Darius wrote:Yep we added oil to both. The weird thing is that it makes noise even when the compressor clutch is not engaged.
I figured out what the squeaking was. I accidentally installed the washer on the AC idler pulley outside of the idler cover piece instead of between the bearing and cover piece. So the cover piece was serving as the bearing surface and it was not happy in doing so. I took it apart and put the thick washer where it belonged and the problem was solved.
I'm going to buy a vacuum pump and AC manifold kit so I can charge up my own system this summer. It gets expensive and annoying to pay someone to do something so simple.
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
Hey darius,
any chance you can send me a zenki adapter fitting you do have made, sense the shop is being ghey i think ill just get the other side cut and welded.
-Daryl
SilverRotary
Car: 95 240sx s2 rb25
mines in the mail, thanks Darius. cant wait for it to get here. was 91 today with 710% humidity... stupid Houston
Darius
Daryl,
So you just want the zenki low-pressure hose end that is at the firewall?
silviasgp06
yeah, did you just make a new line or is it an adapter fitting? if its a new line ill get to the garage and yank the one you sent me off this weekend to send back to you.
Darius
Daryl,
I'll e-mail you.
silviasgp06
Got my a/c working!!! Thanks for all the help.
It seems like Im dealing with some heat soaking issues. Ill know for sure once i move one of my fans to a puller position, but as expected my water temp runs alot hotter with the ac on. ~100*c so I really need to take care of it
Ill send back the kouki line as soon as I get some spare money to mail it back.
-Daryl
Darius
Awesome! Mine never got that hot. I have SPAL pushers on the front of the condenser too. Good pullers and good duct work should do the trick for you. :woot:
rob912
Car: 91 240 rb20
can the s13 rb20 guys get some love lol
i have no idea how to set my a/c up and im moving to florida in august :ohno:
Darius
eek. I dunno. I currently don't have fittings for either of those to go off of. Do you have S13 lines you can send me so I can compare them to what I already have made up? That would at least get me started on it.
marshallpre1
rob912 wrote:can the s13 rb20 guys get some love lol
X1000 (for RB25)! I would want to buy the parts, but I want to make sure it can be done.
Thanks,
Jeremy
Darius
Does anyone have hose ends from their RB20 A/C compressor that I can use to design adapter fittings?
marshallpre1
Oh man, I meant RB25 S13 guys :)
Darius
Same goes for the S13. I would need some high pressure and low-pressure lines to compare with what I have now to see if any of it will fit. Since it probably won't, I would have to design and have new adapter blocks fabbed up.
