RB----->A/C
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Had a fitting leak because a nut backed off. Stuck a lock washer on both, recharged the system, and fired it back up. As the compressor was used more, the squeaking went away and it blows icy cold. Almost too cold haha!
I will e-mail my AC contact list on Monday or Tuesday to update everyone. Anybody else that is interested must e-mail me at [email protected] for info.
nurvcom
Sorry If this has covered
RB20det
didnt have ac compressor
But i Do have KA24E compressor and bracket Would That Work?
and will i need to check inside diameter of both ports to make shurr they match?
Darius
The KA compressor blocks are different than the RB compressor blocks. At least they were on my S14 compressor. Since I have the finished fittings, I can easily compare them to the S14 blocks. I just can't remember off the top of my head what the differences were. Give me a few days to get back to you on that one.
nurvcom
Darius wrote:The KA compressor blocks are different than the RB compressor blocks. At least they were on my S14 compressor. Since I have the finished fittings, I can easily compare them to the S14 blocks. I just can't remember off the top of my head what the differences were. Give me a few days to get back to you on that one.
Thanks
cuss Rb20det doesn't even have a ac bracket
and from what I read everyone here is talking about KA as Dohc model KA24DE
my compressor from Ka24e SOHC
Modified by nurvcom at 8:48 AM 8/24/2009
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
money sent! Cant wait
Darius
Daryl, your kit is ready to ship out tomorrow.
After finally sitting down and trying to remember how my car is wired and after reviewing 300Plus' thread, I created a wiring diagram of the S14 & RB25 systems. Note that the Y/B, B/P, and P wiring connection is made under the passenger side footwell by the ECU.
Enjoy!
Modified by Darius at 9:18 PM 8/30/2009
noodl35
wonder if this works for a r33 rb26 into s14?
Darius
At the end of 300Plus' thread, someone else asked that and I looked up the AC pin on the ECU and it is the same #46 pink wire. So the answer is yes
silviasgp06
brain fart.... what is the wire color "L/R" thats going to the ac comp?
Darius
Blue wire/Red stripe
The RB compressor has a different plug than the S14 harness, so you have to replace both. I just used a weathertight connector from a headlight ballast that crapped out on my gf's car. Soldered it and shrink wrapped it on both ends.
silviasgp06
silviasgp06
got mine today!!!
install tomorrow, hopefully wire, vac, and charge it to. Matt is awesome!
300Plus
Car: 1995 S14 w/ Rb25det Series II
Darius wrote:Daryl, your kit is ready to ship out tomorrow.
Enjoy!
Awesome! I attempted to make a diagram last year and got frustrated and then distracted. This will be easier then reading a whole page
Unit23
Car: 1993 240sx hatchback powered by RB20DET
had to take mine out, kinda sucks because after we finished the swap... my power window amp went out... windows were stick up...
Darius
Good news! I hope the condenser line fits. If it is too short, let me know how short and I'll exchange you for a new line.
I also threw together an installation guide too so I'll e-mail that over to you and Paul. It probably has some holes in it, but it is complete for the most part.
eh?
How much just for the blue line? Do you have that set up instock? I've got everything bolted up and just need to splice that line or get a replacement.
robbie2883
Car: 1998 RB25 Kouki
not trying to bust up your thread darius, just wanted to post up some pics of how we modified my rb bracket to fit the ka compressor. having pics like these would have made it easier for me to understand what needed to be done instead of trial and error. hope these help someone
Darius
That looks awesome! Nice welds too btw. Have you installed the compressor yet? Is it located close enough to the stock location that you can reuse the S14 lines? I'm all for using USDM parts whenever possible on these damned motors. Post some pics up when you get it installed!!
The only thing that concerns me about the stock setup is that the low-pressure line runs underneath the exhaust manifold and between the engine and firewall. Plus, I don't have enough room to do run that line back there with the external head drain lines. So, I reroute the low-pressure line to pass underneath the oil pan and avoid all the heat exposure and conflict.
robbie2883
i am pretty sure you could reuse the stock line if you fought enough to get it into place, but i opted to have a the local a/c shop just make me new high side lines. i ran the stock lines from the core to the firewall but then had them made to go from the core to the compressor and from the compressor to the firewall. I'll get pics for ya but i actually took a que from you and had the lines ran just like urs. even took the pics u posted in so that there'd be no confusion! LOL
Darius
Nice work!
crazyandevil05
Car: 1995 240sx SE, RB25
I just have a rubber hose going from the compressor to firewall, then bending at about the height of the brake master cylinder. i still have the stock turbo heat shield, and even being rubber, its hasnt been a problem. now with no shield, you would need something to block it. probably just some aluminum on adhesive, wrapped around the hose.
Darius
First, the bad news. It has been brought to my attention that the Zenki has entirely different AC fittings than the Kouki. Brilliant move Nissan. I am trying to find some zenki AC lines to borrow so I can get measurements and have hose ends and adapter fittings made up. If anybody has these, I will pay for shipping and only have to borrow them for a week or so. Please e-mail me.
Second, the good news. From a phone conversation with a buddy of mine, it sounds like the S13 has similar firewall fittings to the Kouki. I need to confirm that the hose end I have will fit properly, but the slight possibility is out there for you S13 guys to get AC running in your RB-swapped 240s.
240z4u
Car: '95 Nissan 240SX
Hey buddy, I have all the stock zenki S14 a/c lines in my garage.
Ill email you
Evan
Darius
Thanks for your help Evan! My goal is to get all of this figured out for all S13s and S14s before next summer.
exodus5547097
Do you got any updates on the rb25 s13 a/c yet? I'm just waiting for something to happen. I'm going through south Alabama hot weather in Dec. Crazy huh?
Darius
Had to get more hose ends made because the zenki is different from kouki. I am hoping the s13 is the same as either so I don't have to recreate the wheel.
The other issue is that I don't have an s13 to test it on locally.
SilverRotary
Car: 95 240sx s2 rb25
did anything ever come of this?
Darius
Yep...sorta. I got ahold of some new hose ends for the Zenki, but the shop I use for the adapter fittings is being ghey and jacked up their setup fees on the CNC mill. So far, I have the S14 kouki completely covered, but for the S14 zenki the only thing I don't have is the condenser adapter fitting. It is still on my to-do list, but people aren't knocking down my door for this stuff so I don't have any motivation to spend the time and money necessary to finish the zenki kit.
And I still have not tested any of my stuff on the S13 and am hoping that at least some of the S14 fittings and hose ends will be interchangeable.
240z4u
I thought I sent you all the lines I had for my A/C setup so there should have been zenki condensor fittings in there. Thanks for storing that stuff btw! lmao
Darius
hahahaha I am even storing the box that you sent that stuff to me in too! I had the shop measure all that stuff up but never got the solidworks files completed.
I can take a hint. I'll get back on this :bowrofl:
