RB----->A/C
240z4u
Car: '95 Nissan 240SX
Darius wrote:I am installing the lines on my car tonight to check for clearances. If I can clear the 6boost front positioned manifold, it should be able to get along with most other manifolds.
The adapter blocks are in the last phase of machining. I got pushed back because of some big harley bike they're building. Plus they had a batch of vibrators to make .
Your building vibrators too huh? lol
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I was joking about getting one for a shift knob. I don't think it would be too tough to do
240z4u
Darius wrote:I was joking about getting one for a shift knob. I don't think it would be too tough to do
God please don't start that trend LOL
GIJOE69
Car: Going Side Ways!
any news yet?
crazyandevil05
Car: 1995 240sx SE, RB25
I got mine working well. it gets a bit warm if its over 100 outside, but we're on day 30 something of 100+ highs, so i just cycle it off when it gets up there, after a minute off, it'll be good for another 10-15 on the highway, 75 @ ~3300rpm. just cruising around it wont get hot unless i really stomp on it.I just used the rb compressor and had a shop make the lines. as long as you have the ends they can. let me know if anybody needs pics and i'll email them to whoever. oh, and i was having a problem where it would bog after coming down to idle from higher revs, but fixed that completly when i found out my system was overcharged so i re-did it myself and added more oil.
crazyandevil05
and by warm, i mean the car, not the ac, its wicked cold. and by re-did the a/c, i ment had the system evac-ed and re-charged it myself with the cans from autozone
Darius
I finally have all the parts and hoses in my garage ready for assembly. And I have some of the fittings crimped on hoses in preparation for shipment.
This week will be dedicated to getting the AC on my car installed, evac'd, and charged to test everything out. I will keep you posted on the findings. I'm keeping my fingers crossed that there won't be any major setbacks.
GIJOE69
cool...take lots of pictures and drink plenty of beers! if it is sucesful let me know so I can send payment haha
imotion s14
Car: 1997 240SX
well my a** has been sweaty for 2 months, whats a few more weeks? lol
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
any luck over the past week?
crazyandevil05
Well, the only new things here is its day 52 of over 100. i still have some of the other lines i didnt use for my AC, if anybody needs, i'll see if i have, let me know. or any pics of my setup to see. Shoot me an emial @ [email protected].
Darius
crazyandevil05 wrote:Well, the only new things here is its day 52 of over 100. i still have some of the other lines i didnt use for my AC, if anybody needs, i'll see if i have, let me know. or any pics of my setup to see. Shoot me an emial @ [email protected].
Funny guy. I'm not throwing together some janky kit so it takes time to get it right the first time. I had to return all of the fittings because they missed a gat-damn relief cut for the o-rings. I will have them back by the end of this week or I'll be going over there to b**** someone out.
For a serious update, I have the new lines installed on my car and will have it vacuum tested and charged this coming week. Hopefully, everthing will seal as expected. After that, it is only a matter of shipping.
neonbomb
Good to hear Darius.
I must say, I do miss the nice Iowa breeze this summer. After living away for 5 years, I forgot how humid Pittsburgh is.
silviasgp06
Darius
Vacuum testing on my car is hopefully tomorrow. Depends on how soon my buddy's boss can get ahold of a vacuum pump. By the end of this week for sure.
If vacuum testing goes well, I'll start cutting hose and crimping hose ends on. The returned fittings are supposed to be done by the end of this week as well, so if everything goes as planned, I could be shipping kits out on Monday morning of next week. Just in time to keep silviasgp06 from sweating his butt completely off
imotion s14
Car: 1997 240SX
it's been over 2 months of 100+ heat.. halp.
xDRFTurR1D3x
Car: 98 kouki- S2 RB25- f*ck you fed ex and mother nature!
93 s13.4 kouki/coupe- bottle fed modded KA- VH45 almost ready!
did you ever get the adapter plates finished as well? im still very interested once you get this done man! and to verify this is for a ka a/c pump correct?
Darius
Yep, sort of. I received the adapter fittings but the damn machine shop forgot to machine an inside diamter to receive the o-rings, so I had to send them back. I'm going to make sure they're done today or Monday. I have one set currently installed on my car and I'm waiting to get it vacuum tested to make sure it doesn't leak. If I'm confident none of the fittings leak, I'll start sending sets out.
It looks like the two compressor lines with custom hose ends, custom adapter fittings, and charge ports on the high and low pressure sides along with installation hardware will run $175+SH. I just bought a drier from O'Reilly's to replace my old one and it was only $25. And I'm just reusing my passenger side lines with a little bending here and there to get them to fit. So if you have a working compressor, condenser, triple pressure switch, evaporator, and interior fan, you can get your AC working for about $215 total.
I realize a couple of you are looking for the passenger side lines too. I have a custom drier on backorder which will eliminate the need for two more billet fittings, so that additional billet fitting, lines, hose ends, and drier will run $275+SH. I have the fittings already made, so it is only a matter of fitting the drier in the same location as the stock unit and making hoses for it. I don't know what NISSAN charges for new passenger side lines, but it might be cheaper to just bite the bullet and get them. I'll look into that this afternoon.
xDRFTurR1D3x
sounds AWESOME man! good job! i was under the impression you were getting some plates made to mount the ka a/c compressor to the rb block?
silviasgp06
yess! my butt is pretty sweaty, hoping it wont be by the time class start in 2 weeks so im not sweating in Air Force ABU's (f'ers are thick!) on the drive from UTA to TCU twice a week for ROTC.
Keep it up man!
Darius
-Getting my system vacuum tested tonight. -Adapter fittings should be going on the lathe today to be completed.-Low-pressure hoses should be complete tonight. -High-pressure hoses have one fitting crimped on, but I need to custom cut each according to each person's individual measurement between the timing cover and radiator core support. I also need everyone to verify that they have a 13mm high-side port and a 19mm low-side port on their compressor to make sure these adapter fittings will work.
crazyandevil05
hey, sorry for the small leave of absense, i went and had the 2 lower bertabrae in my back fused. they went through the front, and it is a b**** painwise. and i cant sleep, not to mentioni get these weird hallucinations from the really strong meds.and darious, if you took it like i ment you were jenky-ing it together, far from it. you've put alot more into your's than i have, and detailed it so everybody gains from your work. good lookin out man!
Darius
$hit man, I hope you're alright! Did you get into an accident or something? I remember my dad having to get a cortizone shot in his neck vertabrae, but they went in through the front of his neck with an 8-inch needle. SCREW THAT! LOL
Don't fight the meds so hard, enjoy what little time you get to spend with them :D
Seriously, hope you heal up soon.
silviasgp06
"I also need everyone to verify that they have a 13mm high-side port and a 19mm low-side port on their compressor to make sure these adapter fittings will work. "
not to sound stupid, but how do I verify this? is this the nut size or the inner diameter of the port on the a/c compressor?
thanks!
Darius
Not a stupid question at all! If you look down at the compressor from the driver's side fender. The high-pressure port is on the left and the low-pressure port is on the right. Both ports have a 1/4" stud sticking out above them.
I just need you to measure the inside diameter of both ports. The left one should be about 13 mm and the right one should be about 19mm. If this is what you find, perfect! If not, we'll have to figure something else out.
Just verify that the ports are the correct diameters and give me the distance from your timing belt cover to the radiator support and mount system that you have installed.
Now, the moment many of you have been waiting for...I HAVE A CHARGED AC SYSTEM!!!!
Now I haven't confirmed that it works because my dumb self forgot to install my AC belt before heading over to the shop. So we did everything we could without being able to use the compressor to suck down the last of the second can. But once we got it to seal, it was smooth sailing. I will provide details later, but none of the sealing issues were with the new fittings so I'm STOKED!!
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Darius
Installed the belt last night and fired up the AC. It blows cold, but the compressor is making a whining sound like a bearing is on its last leg. I'm going to see if I can get the last half of a can of refrigerant added along with some more PAG oil tonight. Hopefully it will straighten itself out or I'll be in the market for either a compressor rebuild or a different compressor.
Either way it goes, I'm running this compressor until it dies
silviasgp06
F'n Awesome!
btw I have confirmed that I have 13mm and 19mm ports
what part number did you have for the AC belt, think Ive looked in the stickies but havnt seen it. >checking again...
awesome, so hopefully this weekend ill be prepping the car to receive AC. Gotta remove the comp and clean off dirt on port(pray that there is none inside), and I have to mess with the hose bracket near the compressor cause its making contact with the compressor pulley.
pay pal ready
300Plus
Car: 1995 S14 w/ Rb25det Series II
did you put the oil in the condenser and evap? I know it wouldn't fix the problem with the compressor bearing but a lot of people forget to do that. It helps with a lot with heat exchange. glad you got yours working man, mine still blows so cold I can't stand it and cycles as it should.
Darius
Yep we added oil to both. The weird thing is that it makes noise even when the compressor clutch is not engaged. So I don't know how this is going to turn out in the long run.
I'm just excited that the adapter fittings work, the hose ends work and the drier that I had to modify works. I bought a drier for a 97 240SX (PN 33597 everywhere) and the ports were too small. I had to drill them out while blowing compressed air in the opposite port to keep the aluminum shavings from dropping into the drier. That was another BS situation that pissed me off about the whole charging process...Not even the USDM parts fit for me!
