silpena »
https://forums.nicoclub.com/silpena-u34788.html
Mon Sep 29, 2008 10:11 am
You can clear coat it but your not gonna have much or little corrosion protection. Most clears arnt meant to be sprayed over any acid etches or substrates that provide corrosion protection. PLus you bettr make sure you sand the metal hella good becuase unlike paint and primer. Clear has no filling abilities so every scratch, nick even hair line scratches will show. You bettr muscle up to sand the whole with 320-600 grit to perfection. Metal is hard to sand at that grit. UNlike body filler its not soft. Heal even sanding glazes are hard to sand with 320. Id advise you dont do it unless you have the time and dedication to sand the body down with that fine of grit. BUt hey, at least youll save a tons on primer, paint, sand papers and tools .
