[QUOTE]Originally posted by aleph1 "]Thanks jamie your info helps a lot.
Hey no problem, I'm glad it was of some use. Looking at JWT's site, they have a picture(small) of the inside of a 240 ECU. If you notice, all the IC components are surface-mount(ie not quickly desolderable w/out damage, or socketed for easy removal). Nissan apparently had little intention of providing future 'upgrades' to their stock ECU's, although I'm not sure how commong this really is.I have not opened the ECU yet, so I have never seen the inside, so I am unaware of the whole daughterboard issue.
Neither have I, personally. I briefly read over the first URL you posted, and you are correct about the daughterboard. This some-what negates my above comment about upgradability. More than likely this is a 'piggyback' connector which will allow an alternate data ROM to be installed along with the stock one. More or less overrides the onboard data.
If I do end up mapping it all out correctly and am able to reprogram it to work with my own specs, I suppose it could be a worth while investment for myself and others...
Yes you are certainly correct here - ECU retuning seems to have a very discrete niche in the auto ind. For instance a 32pin EPROM only runs around $1-2 at most... very large proffit potential.
I speak for myself here, but there's a big difference between being able to rewrite the data, and knowing what data to write. I'm not educated enough with tuning to be able to make these sort of decisions/calculations on my own.
It would be even more helpful if someone that has a JWT KA24DE ecu could dump that ...
Yep, if one had a JWT they could find the apropriate burner based on the ROM they(JWT) used. This would be easier than trying to work with Nissans'. And as always I'm sure there are legal/patent issues involved with this daughterboard from JWT should someone decide to mimick it in quantity.
And BTW, that last URL you posted is indeed a good read.
-Jamie
