tercel drifter »
https://forums.nicoclub.com/tercel-drifter-u76962.html
Tue Mar 24, 2009 1:55 pm
Bar of soap does work, but you may aswell go to canadian tire and get the belt spray but dont get belt dressing that stuff is really messy and you'll hate yourself for using that stuff once you work on your car.
So if you got a new belt and still makes noise i'd tighten the belt up more or maybe it could be the second belt?... (don't know e50z)
It could maybe be a worn bearing on one of the pullys.
But if you say its when you turn the wheels all the way in one direction that's probably the relief valve on your power steering pump while you hit the stop screw.
btw don't take ur car to canadian tire
