louiegz »
https://forums.nicoclub.com/louiegz-u10925.html
Mon Feb 26, 2007 6:59 am
As some of you know, I snapped the water pump belt and my Q is at the mechanics now. He found a bad pulley so he's changing all the belts and the pulley with OEM parts. When he was looking in there, he said my radiator is starting to crack. He recommended replacing it. Fair enough. It is original. My question is if that radiator can be re cored or repaired. If I have to change it then that’s fine too. I was thinking since I did overheat a little on Friday, should I wait to see if there's anything wrong with my Q, or get it done and probably save a little on labor since the car is there and it's probably accessible now. Mind you, the overheat was for about 2-3 munites in 30 degree weather, so I'm assuming nothing real bad happened, but you know what happens when you assume.
