VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Dec 28, 2024 4:03 pm
The reservoir is pressurized, like a lot of recent Nissan products. Under normal circumstances the reservoir should only be at or near max with the engine warm. It should be someplace in the middle cold. The only time you fill it to max is when bleeding air from the system, you warm it up, fill it to max, then let it cool. Air gets expelled into the reservoir through the pressure valve each time the engine warms, then as it cools the vacuum valve allows fresh fluid in to supplant the air. You repeat that until the level in the bottle no longer drops.
A bit of air in the system after 3 years is normal, and you should let it stabilize between min and max, not keep filling it to the top. If you keep losing that same 1/4" repeatedly after it stabilizes in the middle, then you may have a small leak.
