VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Sep 28, 2021 9:59 am
You can certainly swap-in a 4WD ECM and TCM, but since the TCM is inside the Valve Body, finding out the right ID for the TCM and simply reprogramming it has to be easier. I didn't address the Transfer Case Controller, but that's a different can of worms and much more complicated. The harness wiring will be absent on a 2WD and you'll need to create it, so if you have no electrical talent, you're probably asking for big trouble trying to undertake a swap like this. I'd imagine you can kluje-wire the transfer case with mechanical switches and no safeties, but don't dare "miss" with the locks. The first time you do, you'll very likely blow something up.
