QX4 coil pack questions
9899pathfinder
Recently got a "cylinder 2 misfire" on my '03 QX4. I replaced the coil pack but soon thereafter got the same code for #5 cylinder. 2 questions:
1) Is this typical; ie, do the packs usually fail at around the same time? In my case, about 80K since the last packs were installed.
2)I tested the primary & secondary resistance on the failed #2. Primary gave a result which I believe was in spec but secondary test revealed no resistance. That obviously could explain it's failure. But after resetting with an OBD II, the QX4 ran ok intermittently. Soon, however, I got a "Service Engine" light and the car ran rough so eventually I replaced the pack. Question is, why would the engine return to running normal, even for a brief time, if the secondary had no resistance at all?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
9899pathfinder wrote:
Mon Oct 31, 2022 8:15 pm
Old age happens, but the vast majority of the time, coils that fail in groups are from poor engine grounds.
D-Rock81
Car: 2001 Infiniti QX4
Heat soak. The best way to check coils imo is with an oscilloscope. Heat and load are important factors when dealing with failing coils. A multimeter test is not a definitive
test for a bad coil.
